Select Cols > New Columns.
Next to Data Type, select Row State.
Click OK.
Right-click and select Row States Cells.
Copy from Row States replaces the row states in the column with the row states from the rows.
Add from Row States adds the row states from the rows to the row state column.
Copy to Row States replaces the row states in the rows with the row states from the column.
Add to Row States adds the row states from the row state column to the row states in the rows.
Right-click a cell and select Row States Cells > Select/Deselect.
To remove the highlight, right-click on the cell and select Row States Cells > Select/Deselect.
