JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Consumer Research
• Categorical Response Analysis
Analyzing Survey and Other Counting Data
The Categorical platform tabulates and summarizes categorical response data, including multiple response data, and calculates test statistics. The strength of the Categorical platform is that it can handle responses in a wide variety of formats without needing to reshape the data. It is designed to handle survey and other categorical response data, such as defect records, side effects, and so on.
Categorical Analysis Example
Contents
Categorical Platform Overview
Example of the Categorical Platform
Launch the Categorical Platform
Response Roles
Cast Selected Columns into Roles
Other Launch Window Options
The Categorical Report
Share Chart
Frequency Chart
Categorical Platform Options
Report Options
Statistical Options
Free Text Report Options
Structured Report Options
Additional Examples of the Categorical Platform
Multiple Response
Response Frequencies
Indicator Group
Multiple Delimited
Multiple Response by ID
Mean Score Example
