To see a list of all display boxes that you can create, select the JMP Help menu and then select Scripting Index > Functions > Display.
To see a list of all display boxes that can be found in a display tree, select the JMP Help menu and then select Scripting Index > Display Box. If a display box is in this list but not in Functions, then you can send messages to it, but you cannot create it in a script. These display boxes are typically sub-boxes of other display boxes.
