a plot of the average measurement values for each combination of the part and X variables. The Average Chart helps you detect product variation despite measurement variation. In an Average Chart, out of control data is desirable because it detects part-to-part variation. See Average Chart.
(only appears if you selected Range as the Chart Dispersion Option in the launch window) a plot of the variability statistic for each combination of the part and X variables. The Range Chart helps you check for consistency within subgroups. In a Range Chart, data within limits is desirable, indicating homogeneity in your error. See Range Chart or Standard Deviation Chart.
(only appears if you selected Standard Deviation as the Chart Dispersion Option in the launch window) a plot of the standard deviation statistic for each combination of the part and X variables. The Standard Deviation Chart helps you check for consistency within subgroups. In a Standard Deviation Chart, data within limits is desirable, indicating homogeneity in your error. See Range Chart or Standard Deviation Chart.
a report that computes several statistics to help you assess and classify your measurement system. See EMP Results.
an Analysis of Means chart for testing if the X variables have different averages. See Bias Comparison.
an Analysis of Means for Variances chart for testing if any of the groups have different test-retest error levels. See Test-Retest Error Comparison.
an interactive set of charts that you can adjust to see the probabilities of getting warnings on your process behavior chart. See Shift Detection Profiler.
Note: This report is similar to the Variance Components report in the Variability Chart platform, except that it does not compute Bayesian variance component estimates. For more information, see Variance Components in Variability Charts.
Note: This report is similar to the Gauge R&R report in the Variability Chart platform, except that the calculation for Reproducibility does not include interactions. For more information about Gauge R&R studies, see R&R Measurement Systems in Variability Charts.
draws the overall mean of the Y variable on the chart.
draws vertical lines to delineate between the X variables.
Note: If you selected Range as your MSA Method, and you have a one factor or a two factor, balanced, crossed model, the statistics in this report are based on ranges. Otherwise, the statistics in this report are based on variances.
the median error for a single measurement. Indicates the resolution quality of your measurement and helps you decide how many digits to use when recording measurements. For more information, see Effective Resolution.
Intraclass Correlation (no bias) does not take bias or interaction factors into account when calculating the results.
Intraclass Correlation (with bias) takes the bias factors (such as operator, instrument, and so on) into account when calculating the results.
Intraclass Correlation (with bias and interaction) takes the bias and interaction factors into account when calculating the results. This calculation appears only if the model is crossed and uses standard deviation instead of range.
For more information about the Profiler and associated options, see Modeling and Multivariate Methods.
The Bias Comparison option creates an Analysis of Means chart. This chart shows the mean values for each level of the grouping variables and compares them with the overall mean. You can use this chart to see whether an operator is measuring parts too high or too low, on average.
select an option from the most common alpha levels or specify any level using the Other selection. Changing the alpha level modifies the upper and lower decision limits.
Show Decision Limits draws lines representing the Upper Decision Limit (UDL) and the Lower Decision Limit (LDL) and defines those values.
Show Decision Limit Shading adds shading between the UDL and the LDL.
Show Center Line draws the center line statistic that represents the average.
Point Options changes the chart display to needles, connected points, or points.
The Test-Retest Error Comparison option creates a type of Analysis of Means for Variances chart. This chart shows if there are differences in the test-retest error between operators. For example, you can use this chart to see whether there is an inconsistency in the way that each operator is measuring.
