JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Statistical Details
Statistical Details
This appendix discusses Wide Linear methods and the use of the singular value decomposition. It also gives details on computations used in multivariate tests and exact and approximate
F
-statistics.
Contents
Wide Linear Methods and the Singular Value Decomposition
The Singular Value Decomposition
The SVD and the Covariance Matrix
The SVD and the Inverse Covariance Matrix
Calculating the SVD
Multivariate Tests
Approximate F-Tests
