Domain Viewer
This report aids in the review of study domains for a selected set of subjects meeting specified population, WHERE statement, and Data Filter criteria. It merges the relevant data sets based on their review flag values.
Report Results Description
Running this report with the Nicardipine sample setting and default options generates the output shown below.
The Results contains the following elements:
Domains
This list contains special, findings, events, and interventions domains, including split domains, that are available for the current study. Many drill-down actions are applied to the currently selected domain.
Domain Viewer
This section summarizes the definitions associated with records involved with the comparisons between snapshots for the specified domain. If this is the first time the study has been added, all records are shown as New.
It contains the following elements:
• | One Legend. |
The legend associates color coding with record status. In the example shown above, new, modified, stable, non-unique, and dropped records are indicated with yellow, red, green, black, and blue coloring, respectively.
• | One Table |
The domain data table is shown embedded in the dashboard.
Action Buttons
Action buttons, provide you with an easy way to drill down into your data. The following action buttons are generated by this report and are based on the currently selected Domain:
• | Add Notes: Click ![]() |
• | View Notes: Click ![]() |
• | View Domain: Click ![]() |
• | Remove Stable Records: Click ![]() |
• | View Domain Notes: Click ![]() |
• | Show Dropped Records: Click ![]() |
• | Show Duplicates: Click ![]() |
• | Show Domain Keys: Click ![]() |
The following action buttons are generated by this report and are based on the currently selected record(s) (row(s)):
• | Patient Profiles: Select subjects and click ![]() |
• | Create Subject Filter: Select subjects and click ![]() |
• | Add Record-Level Notes: Select records and click ![]() |
• | View Record-Level Notes: Select records and click ![]() |
Tip: All record-level notes (user and JMP Clinical defined) for the selected Domain are visible using . All subject- and record-level notes (user and JMP Clinical defined) for the subjects of the selected records (rows) are visible using .
The output of this report includes data tables with records color-coded by record-level review flags.
Report Options
Filtering the Data:
Filters enable you to restrict the analysis to a specific subset of subjects. You can also filter based on population flags (Safety is selected by default) within the study data.
If there is a supplemental domain (SUPPXX) associated with your study, you can opt to merge the non-standard data contained therein into your data.
See Select the analysis population, Select saved subject filter, Merge supplemental domain, and Additional Filter to Include Subjects for more information.
Note: Subjects not meeting filtering criteria remain in the domains but are not surfaced in the viewer.
