Navigating the Help System
How do I access the Help system in JMP Clinical?
The JMP Clinical Help system can be accesses from several paths.
8 Click the “?” link at the top of any report to see a description of the analysis, including requirements.
To find specific information within the Help system, use either the Table of Contents or the Search options, as shown below:
Text Conventions
The following text conventions are used throughout this manual.
Table 1.1
Symbol/Font/Style
Used to designate:
8
Instruction or task to be performed
A > B > C
Navigation path from A to B to C, used for paths through nested directories
A > B > C
Navigation path from A to B to C, used for paths through nested menus
or
Buttons
Load Clinical Setting
Commands
General or Options
Columns, fields, headings, panes, parameters, reports, tabs, and s
Sample Data\example.sas7bdat
Data tables, files, folders, and paths
600 or var:
Text to be entered by you
Note: Notes appear like this.
Notes, tips, cautions, warnings, and other important messages
Where do I find the Trouble Shooting section of the JMP Clinical Help system?
The Trouble Shooting section of the Help is found in the Appendixes.
