Analyze:
You can use this parameter to specify either the findings variable or the summary statistic used to examine for constancy across the study.
Findings Variable (Constant Findings and Summary Statistics)
Choose a particular findings variable type to examine for constancy across the study.
The options are described in the table below.
Option |
Performs the analysis for all findings domains, using: |
Numeric results in standard units |
xxSTRESN |
Character results in standard format |
xxSTRESC |
Results in original units |
xxORRES |
To Specify the Analysis Target:
8 | Click on the radio button corresponding to your choice. |
Summary Statistic (Summary Statistics)
Choose a summary statistic of xxSTRESN to analyze.
Available options are described in the table below.
Option |
Performs the following analysis: |
Mean |
A t-test compares the test mean for each site to the test mean of remaining sites. |
Variance |
An F-test will compare the test variance for each site to the test variance of remaining sites. |
Skewness |
The ratio of the skewness for a given site compared to remaining sites is presented. |
Kurtosis |
The ratio of the kurtosis for a given site compared to remaining sites is presented. |
To Specify the Statistic to Report:
