Navigating the Help System
How do I access the Help system in JMP Clinical?
The JMP Clinical Help system can be accesses from several paths.
8 | Click the “?” link at the top of any report to see a description of the analysis, including requirements. |
To find specific information within the Help system, use either the Table of Contents or the Search options, as shown below:
Text Conventions
The following text conventions are used throughout this manual.
Symbol/Font/Style |
Used to designate: |
Instruction or task to be performed |
A > B > C |
Navigation path from A to B to C, used for paths through nested directories |
A > B > C |
Navigation path from A to B to C, used for paths through nested menus |
or |
Buttons |
Load Clinical Setting |
Commands |
General or Options |
Columns, fields, headings, panes, parameters, reports, tabs, and s |
Sample Data\example.sas7bdat |
Data tables, files, folders, and paths |
600 or var: |
Text to be entered by you |
Note: Notes appear like this. |
Notes, tips, cautions, warnings, and other important messages |
Where do I find the Trouble Shooting section of the JMP Clinical Help system?
The Trouble Shooting section of the Help is found in the Appendixes.
