Term Level
Use this option to specify which level of terms (for example, adverse event, intervention, or MedDRA) to use as categories.
Possible term levels are report-specific and are listed in the following table:
Term Level1
Corresponding Variable
Function
Preferred Term (PT)
AEDECOD in AE
Uses a dictionary-derived text description of the adverse event, listed in the AEDECOD column in AE, that defines the corresponding value in the AETERM or AEMODIFY column.
A preferred term is restricted to a single medical concept.
Verbatim Term (VT)
AETERM in AE
Select this option to use the term as listed in the adverse event term variable.
Verbatim terms are identified by values within the reported term (AETERM) variable of AE.sas7bdat data set.
Body System
AEBODSYS in AE
Uses a dictionary-derived text description of the affected body system, listed in the AEBODSYS column in AE.
High(er) Level Term (HLT)
AEHLT in AE
A superordinate descriptor for multiple preferred terms (PTs).
High(er) Level Group Term (HLGT)
AEHLGT in AE
A superordinate descriptor for multiple higher level terms (HLTs)
Standard MedDRA Query
Grouping of MedDRA terms, at a defined level, that describes a specific medical condition.
Primary System Organ Class (SOC)
AESOC in AE
Uses Primary System Organ Class level of adverse events as categories.
Lowest Level Term (LLT)
AELLT in AE
Uses Lowest Level Term level of adverse events as categories.
Body System or Organ Class
AEBODSYS in AE
Uses Body System or Organ Class level of adverse events as categories.
Dictionary-Derived Term
AEDECOD in AE
Uses Dictionary-Derived Term level of adverse events as categories.
Reported Term for the Adverse Event
AETERM in AE
Uses Reported Term for the Adverse Event level of adverse events as categories.
Reported Name
either CMTRT (for Concomitant Medications) or SUTRT (for Substance Use)
Uses Reported Name level of intervention as categories.
Standardized Name
either CMDECOD (for Concomitant Medications) or SUDECOD (for Substance Use)
Uses Standardized Name level of intervention as categories.
Note: The dictionary name and version used to generate the descriptions should be included as part of the submission.
To Specify the Term Level:
8 Select the term level corresponding to the adverse event terms that you want to use from the drop-down menu.
