Findings Domain Tests for Analysis
Use the text box to specify the Findings tests from the selected domain to include in the analysis.
To Specify the Findings tests:
8 | Click ![]() |
8 | Select the tests you want to include in the analysis and click to add those variables to the text box. |
In this example, ALP and BILI were selected and added.
To Specify the Same Findings Tests Across Multiple Findings Reports:
8 | Open the first Findings report. In this example, we are using Findings Time Trends. Select the desired Findings tests as described above. |
The filled text field is shown below:
8 | Highlight all of the tests in the field and press Ctrl-C to copy them. |
8 | Open the next report (in this example, we'll use Findings Waterfall Plots) and click ![]() |
8 | Paste the copied tests into the text box at the top of the window. |
The Findings tests are subsetted and only the selected tests are shown in the window.
8 | Highlight the tests and click . |
The findings domain tests originally selected in Findings Time Trendsare now selected in Findings Waterfall Plots.
8 | Repeat for additional Findings reports. |
