Lab Test Short Name for Creatinine
Use this text field to specify the Test Short Name (LBTESTCD) value that corresponds to the creatinine test.
By default, attempts to detect common recommended values for the creatinine test. If it finds one, the report automatically enters it in the text box. If an alternative designation is used in your study, the field is left blank and you must specify the designation.
To Specify a Short Name for the Creatinine Test:
8 | Click ![]() |
8 | Select the designation for the creatinine test and click to add the test name to the text box. |
