JMP Script Output File Name
The JMP Script Output File Name field is used to specify a name for the output JMP Script file(s). The suffix .jsl is added to the specified name.
If no name is specified here, the name of the report with Script.jsl appended, is specified by default.
To Specify an Output JSL File Name:
8 | Click in the field and enter a name for your study. |
8 | For example, type Nicardipine_Results in the text field. |
The resulting JSL file is named: Nicardipine_Results.jsl.
