Number of Duration Time Windows
Use this field or slider to specify the number of time s into which you want to partition the total exposure duration.
Note: This parameter is enabled only when Set Number of Duration Time s is selected in Duration Time Window Method.
To Specify the Number of Times to Plot:
8 | Select either Days or Weeks as the Duration Time Scale. |
8 | Select Set Number of Duration Time s in Duration Time Window Method. |
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
