Number of Time Windows
Use this field or slider to specify the number of time s to use for plotting your observations.
Note: This parameter is enabled only when Set Number of Time s is selected in the Class Variables parameter.
To Specify the Number of Time s to Plot:
8 | Select the time scale to use in the Time Scale parameter. |
8 | Select Set Number of Time s in the Class Variables parameter. |
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
