Summarize multiple records per day using:
Use this option to specify the summary statistic for summarizing the results when a specified test occurs multiple times on the same day.
To Specify the Statistic Used to Summarize the Data:
8 | Select the summary statistic that you want to use from the drop-down menu. |
