Summary Statistic for Findings Data
Use the drop-down menu to select the statistic used to summarize the data from the LB, VS, and EG domains.
Options are defined in the following table:
Summary Statistic |
Definition |
Min |
Mean |
Median |
Max |
Last |
To Specify the Statistic Used to Summarize the Data:
8 | Check the Create summary statistic variables for numeric findings box to activate this field. |
8 | Select the summary statistic that you want to use from the drop-down menu. |
