x-Axis for Volcano Plot
Use this drop-down menu to specify the statistic to use on the x-axis of the output Volcano Plots.
Choose: |
When you want to: |
Risk Difference |
Use the difference in estimated proportions. |
log2(Relative Risk) |
Use the ratio of the proportions of occurrences on a log2 scale. so that a unit change corresponds to a doubling |
log2(Odds Ratio) |
Use the ratio of the odds of occurrence between two groups on the log2 scale. The Woolf-Haldane estimate of the Odds Ratio is used if any of the table cells are equal to 0. Note: For rare events (occurrences), the odds ratio approximates the relative risk |
To Specify the Statistic to Plot on x-Axis of the Volcano Plots:
8 | Use the drop-down menu to select the desired statistic. |
