Perform incidence analysis using the following SMQs:
Use this feature to specify how the incidence analysis is to be performed.
Available options are listed in the following table:
Option |
Description |
Narrow search at the individual SMQ level |
Performs an analysis of narrow SMQs terms. For hierarchical SMQs, does not consider any sub-SMQs that might be a part of the SMQ when calculating incidence. |
Broad search at the individual SMQ level |
Performs an analysis of broad SMQ terms. For hierarchical SMQs, does not consider any sub-SMQs that might be a part of the SMQ when calculating incidence. |
Narrow search cumulative for level 1 SMQs |
Performs an analysis of narrow SMQ terms. For hierarchical SMQs, reports only the level 1 SMQs and includes all sub-SMQs when calculating incidence. |
Broad search cumulative for level 1 SMQs |
Performs an analysis of broad SMQ terms. For hierarchical SMQs, reports only the level 1 SMQs and includes all sub-SMQs when calculating incidence. |
Algorithm SMQs only |
Performs an analysis of SMQs that have an algorithm as part of the definition. Note: There are a very limited number of SMQs with algorithms. |
To Specify the Type of Analysis:
8 | Click within the appropriate radio button. |
