Number of Monte-Carlo Samples
Specify the number of Monte-Carlo samples to compute for exact p-values.
Note: A larger number provides a more accurate p-value but can significantly increase run time.
To Specify the Number of Monte-Carlo Samples:
8 | Check the Calculate exact Mantel-Haenszel p-values box to enable this field. |
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
