Group 2
Use this feature to specify the second age group. Age is specified assuming an age unit (AGEU) of years. By default, a minimum age of 65 years has been specified.
This feature is available only when the Set Age Groups check box has been checked. You must specify this age group when the Set Age Groups box has been checked.
Syntax:
You must specify a group definition using SAS syntax, as specified for Group 1.
To Specify an Age Group Definition for Group 2:
8 Enter the definition in the text box.
