Use result or finding in:
Use this option to specify whether results are reported and used in standard or original units.
Check this box to display Findings tests on the log scale for the Y axis on the Time Trend Plots.
Select Standard units to use xxSTRESN (or xxSTRESC when xxSTRESN is missing). Formats are applied only to xxSTRESN values.
Select Original units to use xxORRES; formats are applied to numeric values in this case.
Note: Either LBSTNRHI and LBSTNRLO or LBORNRHI and LBORNRLO are used to determine abnormality criteria for either standard or original units, respectively, for numeric values for the LB domain. LBSTRESC is used.
To Specify This Option:
8 | Make sure that the Include a findings domain in the narrative check box is checked. |
8 | Click within the check box. |
