Include events with overall percent occurrence greater than
Use this option to specify a minimum percentage value for patients experiencing an event. A variable for each unique value of event xxDECOD is included as long as this percentage of patients (or more) experiences this level.
The overall percent occurrence is the percent occurrence of each event/intervention (as chosen by the Term Level option) in the entire population of subjects being analyzed, honoring any subject filters that are applied.
The default value is set to 0%.
To Specify a Value:
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
