Include interventions with overall percent occurrence greater than
*Use this option to specify a minimum percentage value for patients experiencing an intervention. A variable for each unique value of an intervention in xxDECOD is included as long as this percentage of patients (or more) experiences this level.
The default value is set to 0%.
To Specify a Value:
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
