Use this option to convert your en formatted data sets to U8 format.
8
Click the option to open the Convert Datasets to U8 Format window.
8
Enter the filepath to the folder containing the data sets to be reformatted. Alternatively, click to open a Browse window where you can navigate to the desired folder.
8
You must also specify the folder where the reformatted data sets are to be placed.
8
Finally, you must specify an output folder where the log file and other files generated by the reformatting process are to be placed. You may specify the same folder as that used to store the U8 files if you want to keep everything together or a separate folder if you want to keep the data and the ancillary files separate.
