Include events with percent occurrence in any treatment group greater than
Use this option to specify a minimum percentage value for patients experiencing an event. A variable for each unique value of event xxDECOD is included as long as this percentage of patients (or more) in any treatment group experiences this level.
The default value is set to 0%.
To Specify a Value:
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
