Display Test Column Names as:
Use this option to select if resulting table column names should be the Test Short Name value or the Full Test Name value.
Test Short Name is specified by default. This option uses TESTCD values as column names and in plots.
Selecting Test Name, sets all of the column names to xxTEST values and these are used in plots.
