Reference subject as:
Use these options to select the term to use when referencing subjects in the narrative.
By default study subjects are referred to as participants.
To Change How Subjects Are Referenced in the Narrative:
8 | Use the drop-down menu to select one of the preset references or to opt to specify you own term. |
8 | If you select <Specified Below>, the text box becomes active for you to enter your preferred term. |
