ALT Elevation greater than
Use this option to specify the cutoff for alanine aminotransferase (ALT).
Values are specified as multiples of the upper limit of normal (ULN). By default, this value is set to 3xULN. Values above the specified levels are considered indicative of possible liver injury.
To Set the ALT Elevation Cutoff:
8 Either enter the desired value in the text field or use the arrows to change the value.
