Concomitant medications are reported in text using:
Use this parameter to specify the appropriate concomitant medication terms to be used in narrative text.
To Specify the Concomitant MedicationTerm:
Choose:
When you want to:
Reported name of drug
Use the name reported in the CMTRT column from CM.
Standardized medication name
Use the name reported in the CMDECOD column from CM.
8 Click the radio button corresponding to the term that you want to use for describing the medication.
