Remove unscheduled visits
Check this option to remove unscheduled visits from the analysis. For a given Findings domain, any record where the VISIT variable (if it exists) contains "unscheduled" (case insensitive) is removed from the analysis
To Remove Unscheduled Visits from the Analysis:
8 | Check the box. |
Note: For some reports, you may have to specify Visits as the Time Scale to enable this field.
