Calculate baseline using:
Specify how the baseline findings measurements should be calculated.
The following test measurements are considered when forming the baseline measurement:
• | those flagged as baseline, and |
• | those taken prior to Study Day 1 |
Choose Last recorded pre-dose measurement to use the last recorded pre-dose test measurement (out of the test measurement pool generated from the above list) as the baseline measurement.
Choose Mean of recorded pre-dose measurements to average these pre-dose test measurements to form the baseline measurement.
Note: When the selected option to calculate baseline is to use the baseline flag and there are two records flagged as baseline, JMP Clinical uses the last record. This differs from JMP Clinical version 8.1, wherein the mean of the flagged baseline values was used.
