Size of Time Window in Days
Use this option to specify the size (in days) of the time to be used in computing time trends. A time of 90 days is specified by default.
Consecutive s of the specified size are constructed between the starting and ending dates.
You should experiment with different sizes to ensure that the size is large enough to capture sufficient data for computing risk indicators but small enough to detect any trends.
This field is available only when the Compute Time Trends check box has been checked.
To Specify the Size of the Time :
8 | Check the Compute Time Trends check box. |
8 | Either enter the desired value in the text field oruse the up and down arrows to change the value. |
