Actual/Planned/Comparison Variable
Use this option to specify the variable describing the actual treatment used, the planned treatment, or a comparison variable. The variable selected here depends on the option selected for the .
Actual Treatment Variable
This option is surfaced when you select Actual as the This variable you select lists the actual treatments the subjects received.
Planned Treatment Variable
This option is surfaced when you select Planned as the This variable you select lists the planned treatments.
Comparison Variable
This option is surfaced when you select Specified Below as the This variable you select specifies the comparison
To Specify the Actual/Planned/Comparison Variable:
8 Select the desired
8 Click to open the Add window, shown below:
8 Select the desired variable and click .
