Glossary
Definitions/Explanations of Terms Used in JMP Clinical Documentation
Term Definition/Explanation
ADaM
Adverse Event (AE)
Alpha
ANOVA
Arm
Bin
Binary Variable
Bivariate
Body System
BY Group
BY Variable
CDISC
Cell Plot
Censor Variable(s)
Character Variable
Chi-square Test
Class Variable
Clustering
Cochran-Mantel-Haenszel Test
Contingency Plot
Contingency Table
Correlation
Correlation Coefficient
Covariance
Covariate
Dendrogram
Dependent Variable
Distance Matrix
Distribution
Double False Discovery Rate (FDR) Adjustment
Drill Down
Electrocardiogram (ECG)
Factor
Familywise Error Rate (FWER)
Field
Fixed Effects
Forest Plot
Geometric Mean
Group Variable
Heat Map
Hepatotoxicity
Hierarchical Clustering
High Level Group Term (HLGT)
High Level Term (HLT)
Hotelling T-squared Test
Hypothesis Test
Hy’s Law
Imputation
Independent Variable
Index Variable
JMP Scripting Language (JSL)
Journal
Kaplan-Meier Survival Curve
Lowest Level Term (LLT)
LSMeans
Mahalanobis Distance
Main Effect
Matched Pairs Analysis
Mean
Medical Dictionary for Regulatory Activities (MedDRA)
Median
Menu Bar
Metadata
Missing Value
Model
Modus Tollens
1. If P, then Q.
2. Not Q.
3. Therefore, not P.
Mosaic Plot
Nominal Variable
Null Hypothesis
Numeric Variable
Observation
One-way ANOVA
One-way Plot
Operator
Ordinal Variable
Overlay Plot
Parallel Plot
PCTL
Percentile
- 25th percentile = first quartile = Q1
- 50th percentile = second quartile = median = Q2
- 75th percentile = third quartile = Q3
Plain Text Format
Power
Preferred Term (PT)
Prior Probability
Pull-down Menu
p-Value
Quantile
Random Effects
Random Number Seed
Regression Analysis
Sample Size
SAS Data Set
SAS Transport File
SAS Variable Label
SAS Variable Name
Scatterplot
Screen Failure
SDTM
Sensitivity
Shift Plot
Specificity
Standard Deviation
Standard Error
Standard MedDRA Query (SMQ)
Standardization
- Transformation of a data set to have zero Mean and unit Variance.
- Making all regression coefficients have the same scale.
- Normalization.
Statistic
Strata Variable
Survival Curves
Survival Plot
System Organ Class (SOC)
Test Statistic
Transformation
t-statistic
t-test
If only one Variable is chosen (one-sample t-test), the null hypothesis is that “the population mean is equal to the given mean”.
Type I Error
Type II Error
Variable
Variance
Venn Diagram
Volcano Plot
Workflow
XML
