A data template controls what domains are shown in subject profiles. It contains a list of included or excluded domains.
To create a new template:
8
Select a template using the Current Data Template drop-down menu (circled above) and either select a template that is closest to the one that you want to create, or just work from the default None template.
8
Specify if you want to include or exclude domains using the Selection Behavior options.
8
Build the domain list by clicking on selected available domains and clicking to add the domains to the Selected Domains list, as Shown above. Hold the key to select multiple subjects or the key to select contiguous subjects among those listed.
8
To save the template, click , enter a template name, and then click to save it. The template is saved and applied to the current profile.
8
To delete one or more templates, click , select the templates that you want to delete, and then click .
