Glossary
Definitions/Explanations of Terms Used in JMP ClinicalDocumentation
Term Definition/Explanation
Accession Number
ADaM
ADSL
Adverse Event (AE)
Alanine Transaminase (ALT)
Allele
Alpha
Alternative Hypothesis
Amino Acid
Analytical Procedure (AP)
ANCOVA
ANOVA
AP
Arm
Aspartate Transaminase (AST)
Bar Chart
BCPNN
Beta
Bin
Binary Variable
Binomial Regression
Bioinformatics
Bivariate
Body System
Bootstrap
Box Plot
Bubble Plot
BY Group
BY Variable
CDISC
Cell
Cell Plot
Censor Variable(s)
Character Variable
Chart
Check Box
Chi-square Test
Chromosome
Class Variable
Clinical Research
Clustering
Cochran-Mantel-Haenszel Test
Color Variable
Conditional Probability
Contingency Plot
Contingency Table
Correlation
Correlation Coefficient
Covariance
Covariate
Cox Proportional Hazards Model
CSV
Delimiter
Dendrogram
Dependent Variable
Deviance Residual
Dialog
Distance Matrix
Distribution
DNA
Dot Product
Double False Discovery Rate (FDR) Adjustment
Down
Eigenvalue
Eigenvector
Electrocardiogram (EG)
Environment
Euclidean Distance
Extensible Markup Language (XML)
Factor
Familywise Error Rate (FWER)
Field
Fisher’s Exact Test
Fixed Effects
Forest Plot
Gaussian Graphical Models
Gene
Geometric Mean
Group Variable
Heat Map
Hepatotoxicity
Hierarchical Clustering
High Level Group Term (HLGT)
High Level Term (HLT)
Hoeffding Correlation (D)
Hotelling T-squared Test
HyperText Markup Language (HTML)
Hypothesis Test
Hy’s Law
Imputation
Independent Variable
Index Variable
Jitter
JMP Scripting Language (JSL)
Journal
JSL
Kaplan-Meier Survival Curve
Kendall Correlation
K-Means Clustering
Label Variable
Leaf
Level
Log-rank Test
Logistic Function
Logistic Regression
Logit Function
Log-odds
Lowest Level Term (LLT)
LSMeans
Macro
Mahalanobis Distance
Main Effect
MANCOVA
Manhattan Plot
MANOVA
Matched Pairs Analysis
Mean
Medical Dictionary for Regulatory Activities (MedDRA)
Median
Menu Bar
Metadata
MGPS
Missing Value
Mixed Model
Mode
Model
Modus Tollens
1. If P, then Q.
2. Not Q.
3. Therefore, not P.
Mosaic Plot
Nominal Variable
Null Hypothesis
Numeric Variable
Observation
One-way ANOVA
One-way Plot
One-way Repeated Measures ANOVA
Operator
Optimistic Bias
Ordinal Variable
Organ
Overlay Plot
Parallel Plot
PCTL
Pearson Correlation
Penalized Logistic Regression (PLR)
Percentile
- 25th percentile = first quartile = Q1
- 50th percentile = second quartile = median = Q2
- 75th percentile = third quartile = Q3
Plain Text Format
Portable Document Format (.pdf)
Posterior Probability
Power
Preferred Term (PT)
Prior Probability
PROC
Protein
PRR
Pull-down Menu
p-Value
Q Matrix
Quantile
Random Effects
Random Number Seed
Regression Analysis
Reliability Diagram
Residual
Rho
Rich Text Format (.rtf)
Root Mean Square Error (RMSE)
ROR
Sample Size
SAS Data Set
SAS Transport File
SAS Variable Label
SAS Variable Name
Scatterplot
Screen Failure
SDTM
Sensitivity
Shift Plot
Singular Value Decomposition
Smoothing Bandwidth
Spearman Correlation
Specificity
Standard Deviation
Standard Error
Standard MedDRA Query (SMQ)
Standardization
- Transformation of a data set to have zero Mean and unit Variance.
- Making all regression coefficients have the same scale.
- Normalization.
Statistic
Strata Variable
Support Vector Machine (SVM)
Survival Curves
Survival Plot
System Organ Class (SOC)
Tall Data Set
Tau Value
Test Statistic
Tissue
Transformation
Tree
Tree Map
Truncated Product Method (TPM)
t-statistic
t-test
If only one Variable is chosen (one-sample t-test), the null hypothesis is that “the population mean is equal to the given mean”.
Type I Error
Type II Error
Variable
Variance
Venn Diagram
Vital Signs (VS)
Volcano Plot
WHERE Clause
Wide Data Set
Wilcoxon Signed-rank Test
Wizard
Workflow
XML
