Multiplier for Upper Normal Limit
Use this option to choose a number by which to multiply the upper normal limit.
Note: This parameter is enabled only when the Create Indicator Variables for High and Low Labs box is checked.
The upper normal limit is defined in the LB data set. Lab values above the multiplied upper normal limit receive a 1 for the high lab indicator, otherwise a 0.
To Specify the Number by Which to Multiply the Upper Normal Limit:
8 | Make sure that the High and Low Labs box is checked. |
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
