Overlay visits when treatment crossover is detected
Check this box to overlay visits when treatment crossover is detected for subjects.
Caution: You should check this box only if you want to overlay findings trends across the same time points (if detected) for treatments from different visits. Treatment crossover periods must coincide with Visits or unexpected results might occur. When this option is checked, any information about which treatment a subject was given at a visit is no longer discernible.
If time points are not detected within visits, this option is ignored.
To Specify This Option:
8 | Choose Visits as the Time Scale. |
8 | Check the Incorporate findings time points in plots box. |
8 | Check the box. |
Note: Refer to Distribution Reports for more information about analysis of crossover data.
