A_T
Specify the assumed constant for A_T. The default value is 3.
To Specify a Value:
8 Either enter the desired value in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
