Specify the Number of Independent Markov Chains
Specify the number of independent Markov chains to generate.
To Specify the Number:
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
