Specify the Rate of Thinning
Specify the rate of thinning (k). MCMC sampling keeps 1 out of every k posterior samples in order to reduce autocorrelation.
To Specify the Rate of Thinning:
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
