Amount of Increment in the Remaining Enrollment (How Often to Simulate)
Specify the amount of increment in enrollment when simulating the remaining time from current enrollment +1 up to total enrollment.
The simulation partitions the remaining number of enrollment by (K2/tick). The total enrollment is added if it is not included already.
To Specify a Value:
8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
