Current Date
Use this option to specify the current date.
Note: This option is active only when the Use the Last Randomization Date as Current Date check box is unchecked.
The date must be entered using this format: YYYY-MM-DD, where DD is the day (numeric), MM is the two-digit numeric designation for the month, and YYYY is the year (numeric). For example, a current date of July 1, 2019 must be entered as 2019-07-01.
To Specify the Current Date:
8 | Make sure the Use the Last Randomization Date as Current Date check box is unchecked. |
8 | Enter the date in the text box using the proper format. |
8 | Alternatively, click ![]() |
8 | Click on the current date to specify the date, shown below; |
8 | To select a different date, October 20, 2019 use the controls to navigate forward or backwards to the selected date. |
