JMP Clinical Review API
The JMP Clinical Review API provides functions for manipulation of JMP Clinical Reviews, Reports, and Sections.
The general usage centers around a reference to a Review Viewer/Builder based on a generated ID. The ID may be obtained via one of several functions below, or will be made available in the context of Review Viewer/Builder executing code embedded within a JMP data table within a Report. The variable JMPClinicalReviewID will be the ID of the Review in which the code is executing. In this way, the script writer may customize output generated by a JMP Clinical Report by simply adding a script to the data table within the Report.
Descriptions of each function is provided below. Additionally, the installed API/example folder contains example scripts which demonstrate the usage of the functions.
Functions:
JMPClinicalReviewAPI:getReviewBuilder
This function gets an instance of a Review Builder. If an instance doesn't exist, one will be created.
Arguments:
show
{show=1} - shows the window
{show=0} - hides the window
Returns:
A reference to the Review Builder object.
Syntax:
JMPClinicalReviewAPI:getReviewBuilder = function({show=1}, {default local},
JMPClinicalReviewAPI:closeReviewBuilder
This function closes the current Review Builder instance.
Arguments:
None
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:closeReviewBuilder = function({}, {default local},
JMPClinicalReviewAPI:openReviewTemplate
This function opens a Review Template
Argument:
templatePath - path to the Review Template to open
Returns:
Syntax:
JMPClinicalReviewAPI:openReviewTemplate = function({templatePath}, {default local},
JMPClinicalReviewAPI:addReport
This function adds a Report, as defined in the Report Definitions, to the Review Builder.
Arguments:
reportDefinitionID - the name/ID of the Report to add (e.g. AEDistribution)
Returns:
Syntax:
JMPClinicalReviewAPI:addReport = function({reportDefinitionID}, {default local},
JMPClinicalReviewAPI:removeReportByReportTitle
This function removes a Report from the Review Builder.
Arguments:
reportTitle - title of the Report to remove
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:removeReportByReportTitle = function({reportTitle}, {default local},
JMPClinicalReviewAPI:runReportByReportTitle
This function runs a Report in the Review.
Arguments:
reportTitle - title of the report to run
completedListener - function to call when the report completes execution. The callback function needs accept a string that will be the Report ID that just ran.
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:runReportByReportTitle = function({reportTitle, completedListener=empty()}, {default local},
JMPClinicalReviewAPI:runAllReports
This function runs all Reports in the Review.
Arguments:
completedListener - function to call when the last report completes execution. The callback function does accept any arguments.
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:runAllReports = function({completedListener=empty()}, {default local},
JMPClinicalReviewAPI:saveReview
This function saves the review.
Arguments:
reviewPath - path of the Review to save
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:saveReview = function({reviewPath}, {default local},
This function opens a review.
Arguments:
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:openReview = function({reviewPath}, {default local},
JMPClinicalReviewAPI:getReviewViewerIDsAndTitles
This function gets the IDs and Titles of all Review Viewers/Builders.
Arguments:
None
Returns:
A list of associative arrays. Keys include:
id - String: the ID of the Review Viewer/Builder
title - String: the title of the Review Viewer/Builder
Syntax:
JMPClinicalReviewAPI:getReviewViewerIDsAndTitles = function({}, {default local},
This function gets an instance of the Review Viewer/Builder.
Arguments:
id - ID of the Review Viewer/Builder
Returns:
References to the Review Viewer/Builder, or empty() if not found
Syntax:
JMPClinicalReviewAPI:getReviewViewer = function({id}, {default local},
JMPClinicalReviewAPI:getReviewTableOfContents
This function gets the table of contents of the Review.
Arguments:
Returns:
title - String: title of the Report
sections - List: List of Strings for the names of the Sections within the Report
Syntax:
JMPClinicalReviewAPI:getReviewTableOfContents = function({id}, {default local},
JMPClinicalReviewAPI:getReportIDList
This function gets the list of Report IDs.
Arguments:
Returns:
A list of ids of the Reports within the Review Viewer/Builder
Syntax:
JMPClinicalReviewAPI:getReportIDList = function({id}, {default local},
JMPClinicalReviewAPI:getReportTitleList
This function gets a list of Report titles.
Arguments:
Returns:
A list of titles of the Reports within the Review Viewer/Builder
Syntax:
JMPClinicalReviewAPI:getReportTitleList = function({id}, {default local},
JMPClinicalReviewAPI:getReportByID
This function gets a reference to a Report.
Arguments:
reportID - ID of the Report (see JMPClinicalReviewAPI:getReportIDList)
Returns:
A reference to the Report object
Syntax:
JMPClinicalReviewAPI:getReportByID = function({reportID}, {default local},
JMPClinicalReviewAPI:getReportByTitle
Arguments:
Returns:
Syntax:
JMPClinicalReviewAPI:getReportByTitle = function({id, reportTitle}, {default local},
JMPClinicalReviewAPI:getReportDetailsByTitle
This function gets the Report Definition associative array for a Report
Arguments:
Returns:
An associative array describing the Report. Keys include:
1 - String: CDISC category
2 - String: Statistical category
label - String: Label of the Report
name - String: Name/unique id of the Report
icon - String: Path to the icon for the Report (using installation.path.preferences notation)
Syntax:
JMPClinicalReviewAPI:getReportDetailsByTitle = function({id, reportTitle}, {default local},
JMPClinicalReviewAPI:getReportResultsByTitle
This function gets a reference to the results namespace of the Report.
Arguments:
Returns:
A namespace with the contents of the Report, empty() if title doesn't exist or Report hasn't been run.
Syntax:
JMPClinicalReviewAPI:getReportResultsByTitle = function({id, reportTitle}, {default local},
JMPClinicalReviewAPI:getReportSectionByTitleAndSectionName
This function gets a reference to Section of a Report.
Arguments:
sectionName - name of the Report Section
Returns:
A reference to the OutlineBox the Report Section, empty() if title or Section name doesn't exist or Report hasn't been run.
Syntax:
JMPClinicalReviewAPI:getReportSectionByTitleAndSectionName = function({id, reportTitle, sectionName}, {default local},
JMPClinicalReviewAPI:getDataTablesForSectionByTitleAndSectionName
This function gets a list of data tables for a Report Section.
Arguments:
Returns:
A list of data tables used by the Report Section, empty list {} if title or Section name doesn't exist or Report hasn't been run
Syntax:
JMPClinicalReviewAPI:getDataTablesForSectionByTitleAndSectionName = function({id, reportTitle, sectionName}, {default local},
JMPClinicalReviewAPI:insertSectionIntoReportByTitleAndSectionName
This function insert a new Section into a Report.
Arguments:
sectionName - name of the new Report Section
displayObject - reference to a DisplayObject to be inserted
insertionIndex - index of where to insert the new Section 0 (default)
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:insertSectionIntoReportByTitleAndSectionName = function({id, reportTitle, sectionName, displayObject, insertionIndex=0}, {default local},
JMPClinicalReviewAPI:removeSectionFromReportByTitleAndSectionName
This function removes a Report Section
Arguments:
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:removeSectionFromReportByTitleAndSectionName = function({id, reportTitle, sectionName}, {default local},
JMPClinicalReviewAPI:appendDisplayObjectToReportSectionByTitleAndSectionName
This function appends a DisplayObject to the end of a Report Section.
Arguments:
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:appendDisplayObjectToReportSectionByTitleAndSectionName = function({id, reportTitle, sectionName, displayObject}, {default local},
JMPClinicalReviewAPI:prependDisplayObjectToReportSectionByTitleAndSectionName
This function prepends a DisplayObject to the beginning of a Report Section
Arguments:
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:prependDisplayObjectToReportSectionByTitleAndSectionName = function({id, reportTitle, sectionName, displayObject}, {default local},
