JMP’s 3-D scene language is built on top of the OpenGL API, extending, replacing, and leaving out various parts of the OpenGL API, and as such is not an implementation that is certified or licensed by Silicon Graphics, Inc. under the OpenGL API.
JMP ships with sample files in the Scene3D subfolder of Sample Scripts to get you started and give you some ideas. Some of the example scripts are similar to some of the examples in this chapter; some are almost complete applications.
The Web site http://opengl.org is a good jumping off point for information, as is your favorite search engine.
Help created on 9/19/2017
