So, in the limit as k becomes arbitrarily large,
tends toward the normal PDF. As
tends toward the exponential (Laplace) distribution.
The regularization parameter k is set so that P(Normal(x) < k) = Huber Coverage, where Normal(x) indicates a multivariate normal variate. Huber Coverage is a user field, which defaults to 0.90.
