Select Help > Sample Data Library and open Cities.jmp.
Select Graph > Contour Plot.
Select Ozone and click Y.
Select X and Y and click X.
Select to Fill Areas.
6.
a.
Select Transform > Range Normalized.
b.
Select Show Control Panel.
The Alpha slider appears.
Contour Plot for Ozone
8.
Click and move the Alpha slider to the right.
Alpha Shapes Filter
Help created on 9/19/2017
