The usual principal inertias of a Burt table constructed from m categorical variables in MCA are the eigenvalues uk from
. These inertias provide a pessimistic indication of fit. Benzécri (1979) proposed the following inertia adjustment; it is also described by Greenacre (1984, p. 145):
for all inertias greater than
, where
is the sum of squared inertias and nc is the total number of categories across the m variables.
