It is possible that effects not included in your assumed model are active. In the Alias Terms outline, add potentially active effects that are not in your assumed model but might bias the estimates of model terms. Once you generate your design, the Alias Matrix outline appears under Design Evaluation. The Alias Matrix entries represent the degree of bias imparted to model parameters by the effects that you specified in the Alias Terms outline. For details, see the The Alias Matrix in Technical Details.
Alias Terms Outline
Once you specify six runs in the Design Generation outline and click Make Design, the Design Evaluation outline appears. Open the Design Evaluation outline and the Alias Matrix outline. See Alias Matrix.
Alias Matrix
Help created on 9/19/2017
